Re: force 125 lower unit
There are three bolts yyou need to remove. There is one underneath the gear housing. DO NOT remove the one on the side of the gear housing. There are also two screws one Vent and one Fill at the top of the lower unit to remove. The one under the gear housing is the drain plug. Pull all three out and the fluid will drain well. Make sure you keep the vinyl washers. If you don't put them back on you might get water in you lower unit. <br />Once drained, use the bottom drain hole to fill the lower unit. (this is the way mechanics told me to do it. Reduces air bubbles) Use pressure to force the fluid up into the lower unit. It is full when it comes out the top (Vent and Fill) holes. Replace the vent and fill screws, then the drain screw. Good luck.
