force 125 carb
BENJA
im trying to rebuild the carbs on this force 125 engine and im not sure which rebuild kit i need. the carb has a number stamped on its 664061. the kit numbers i found that i think i need are fk10103-2 or 18-7037 but not really sure. i think these carbs have the rubber or neoprene seats any. suggestions would be really helpfull
sidenberg
Re: force 125 carb
What is the year of your 125. I have a 1987. I rebuilt carbs last year and found the original needles were all metal but the push in seats had a rubber o-ring that was destroyed due to either ethanol or the carb cleaner I sprayed into it. Regardless I found replacement seats that where all metal that took a needle with a rubber tip on ebay.
BENJA
Re: force 125 carb
I think it's a 86 or 87 we have the same type of carbs do u by any chance remember the part number?
sidenberg
Re: force 125 carb
The needle and seat part # is FK10107, but is obsolete. I was lucky and found a set on ebay last year. These are press in seats not screw in type. Yours may be different however but most likely the same.
BENJA
Re: force 125 carb
Is that the part number u bought and were those the ones with the rubber on the needle and the hard seats?? I found one on eBay but it says the number is fk10107-2??
sidenberg
Re: force 125 carb
Yes, The hard seats, press in type, with the rubber tip. That is what I used and that should work for you. Great that you found some. Careful pulling the old seats out.
