Re: Force 120hp wireing
If the wiring follows the marine color code the tan is the temp (solid tan no color stripe) - it runs from the temp sender to the temp gauge.<br /><br />If the other wire is a solid brown that is usually reserved for the alternator charge light, genrator armature and fuses/switches to pumps. Brown with a yellow stripe is for bilge blowers. Brown with a white stripe is trim sender.<br /><br />Check your temp gauage, bilge pump, blowers, tirm gauage, etc. Make sure everything is working.
