I have a complete tilt unit that came with my boat, owner was going to have it switched out due to the other unit having a leak down problem. that never happened. I am putting power to this unit and no movement at all up or down, I thought it might have had air in it so I took out the front and rear plugs and drained it, then refilled it, I have checked the fluid level periodically so it shouldn't be low on fluid. When I power it you can hear the pump motor kick in in the up or down position, (doing this by just switching pos & neg connections, it sound good spins good but I still am not getting one movement out of the lift unit. It does have pressure on it but I can still pull it up by hand and lower it by hand.
Same unit as my 1990 Force 120hp but I'm sure it would work on a lot of motors. Has the 3 lines going into the side and the one line that connects to the bottom on the pump. Trim ram in the middle and 2 lift cylinders. I don't know what to think. Any suggestions? thank you
