bigdiehl332005
- Jun 25, 2013
- 7
I have a 94 Bayliner Capri 1800LS with a 120 Force and it wont start
heres the story on this boat I bought it about a month ago because I wanted to get back into boating the guy I got it from in Ballard Took me out on the water with it and it ran fine started right up it. between 3/4 full throttle it wouldn't pick up much more speed and he said it had a low compression in the one cylinder. I brought it home and got busy with work finally put on a kicker so incase my main OB went down id be able to get back without a paddle cause that's no fun lol. And here I am it wont start :-( so basicly it got pulled from ballard to Tacoma and that's all the wind its seen
Heres the steps I take to try and start it. turn batteries on/ Lower engine/pump fuel line/ push key in to choke and try to start. I have even tried to put the throttle up a little. kill switch is in the run position and still no luck. I did a compression test and its 125 30 125 120. Im waiting on help to check to see if I am getting any spark kind of hard to do alone. I tried looking for inline fuses or anything but only fuse I can find is right above the coil packs and its fine.
Does anyone have any ideas on why it would of ran a month ago and all of a sudden not run at all?
