Force 120 serial # gone- where else to look?
LKWD
In order to figure out why my engine grinds when I turn the key (won’t start- does have new battery and new fuel lines), I need the year, serial number, etc. The number on the plate is washed off. Any ideas on where else I may find clues to figure this out?
jerryjerry05
IF?? the motor and boat came together as a package??
You can send the Hull ID# to who ever made the boat.
They should have that info.
To find the year? look on the starter, some have a year printed on the side.
Or under the coils and ignition pack on the side of the motor is a round foundry stamp.
The year should be in the center.
Pics of the lower and the transom might help.
roscoe
square fuel pump or round two stage fuel pump?
CD pack ignition or switchbox ignition?
main wiring harness connected to a terminal strip with screws, or are there plug in style bullet connectors on the wires?
