chevyguy420
- Aug 10, 2020
- 11
i have a 1990 force 120 with no spark on cylinders 2 and 3. so far I have replaced the stator and now the trigger with no luck. what else can I check before buying more parts? thanks
thank you! I will try disconnecting the kill wire to the pack and see if the does it.
thanks again! I disconnected the wires from the stator to the rectifier and it fired up, on 2 cylinders but the tach didnt work. I'm off to work now, more playing around tomorrow I guess. I happened to find the exact same motor with a grenaded piston I'm going to buy for parts.
today i have rechecked all the wiring and after changing the wires from the trigger from cylinder 1 to cylinder 2 to the power pack I still had no spark on cylinder 2(same thing with 3 and 4). I then changed the wires from cylinder 1 to cylinder 2 from the power packs to the cdi and had spark on 2 and not 1(same with 3 and 4)
Pin it to win it!
