Re: FORCE 120 HP THERMOSTAT REVERSED was an old l drive block
I am going to remove the thermostat housing and see which hole the water comes out
I can not reverse the thermostat it wont fit with the spring towards the block
I may be able to use the old water cover anyway ...if the water comes out through the block first.
in the older blocks Its looks like it went through the water jacket first , spring faced away from the
heads , opposite of common sense , but may of worked ,, with the 130 degree thermostat instead
of a normal 143 degree ... I can also try a differant thermostat to fit spring side to the block
depends on water flow , I dont want to change the water cover if I dont have to it also holds
the head in place and I not sure if you are suppose to reuse head gaskets ,, Well at least
this is a rebuilt block none of the screws are frozen
