suidjigger
- Aug 24, 2010
- 4
Here is my problom, I have replaced the stator and have checked most things out but need some help figuring out why it wont turn up at high end worked fine but then just wont crank up. Had the same problem a month ago then changed the cdi module and still didnt change anything until i was running it in the water at wot which was rpm about 2700 and i was playing with the trim popped the prop out of the water and motor spead up and put prop back in and she took off like a scared cat. I am lost to why but i had fun for about a month then now back to doing the same thing again.. Any suggestions for me PLS.
desperate person miss the speed.. seems klike she is running on 3 cylinder not four
