Have read several of the post regarding Force problems at WOT or high RPM. Some say clean fuel system. Some point to electronic power packs.<br />My symptoms.<br />1. Idle greats and accelerates to plane smoothly and will run at 3/4 speed.<br />2. Accelerate to WOT and engine bogs down and will only run at ROUGH idle for remainder of day.<br />3. Fuel line bulb is rock hard. Disconnet and bulb will pump plenty of gas.<br />4. Let boat sit overnight and it starts and runs great until you push to WOT. Need to try WOT immediately after starting boat to see if it could be heat related problems with the electronics. Any suggestions ?
