MarcSinger
- Feb 6, 2023
- 6
So figured I’d give an update for anyone in the future, the fuel pump issue was due to a faulty rebuild kit, new kit and no problem with fuel coming out the 90 fitting any longer. After a compression test found 148-151-150-152. Actually surprised it was so high for a 97 motor. But came to the conclusion it was a carb issue. Rebuilt the carbs (again) changed fuel lines, filter (again) and found during carb rebuild it had .094 jets in it. Seemed a little big to me so I went to the Mercury parts website and saw that .088 jets were recommended for my altitude (800ft). Fabricated some jets from a couple of brass screws. Drilled a 5/64 hole (roughly .078) and cut them down to the size of a jet. Boom, she ran perfect, gets the boat up to 40mph running 5100rpm with 4 people and fully loaded with tools and fishing gear. Had some actual .088 jets ordered and put them in and it smoothed out the idle even more and gave a better throttle response. Set timing to 30 degrees ( going for 28 degrees after I do some linkage adjustments) and had it on the water for 4 hrs yesterday without issue. Almost certain the jets were the cause of the problem. Not sure why it had that big of jets in it, especially in NC altitude. Thank you all for your help!
Good Work getting your motor to run!!! I hope I can ask a few questions.
I am looking for suggestions, help, prayers, advice. I don't like giving up and want to understand how it works and what is wrong with it.
I have a Force 120 from 1976 (Yes 1976).
It was running awesome for a year, started to die at idle, and now I cant get it to idle at all.
I did the following:
1. Removed the carbs and rebuilt then with the exception of removing the Welch plugs on the tops of the carbs. (Didn't even know what they were for!?)
2. Replaced the fuel pump 3x. With a "compatible" Amazon version.
3. Installed Clear fuel lines to see if there was any air leaks. (There does seem to be air coming in at the inlet)
4. Checked for Spark on all plugs (Using a timing light on each lead going to the spark plugs. The timing light lit up so I assume the coils are working. I have not pulled the plugs and run them so I can visually see if there is spark.
5. Adjusted Timing using 28 degrees at WOT
6. Tore my hair out
Still wont Idle and I need help.
A. Your post helped me realize there should _NOT_ be fuel coming out the of the "Vacuum" right angle line and I had a ton of fuel in there. So I rebuilt the fuel pump (again 3rd time). I also used a vacuum pump to make sure it would hold vacuum. It seemed promising it was holding vacuum.
B. The fuel line going to the inlet of the fuel pump, after is primed with the bulb, would slowly have air coming into it. I can't figure out from where. So I tightened the 4 bolts on the fuel pump, and the clamp on the fuel line, and unfortunately broke the inlet nipple off the fuel pump. YAY !
C. So... I am waiting for a rebuild kit for my ORIGINAL fuel pump and am going to try again. (I dont think the Amazon pump is making good contact with the engine and gasket, thus the little hole between isn't making good pressure or vacuum to move the diaphragm) But who knows?
D. I also plan to remove the plugs at the top of the carb, and inspect for junk, clean them out, and Try again.
A few questions in general:
1. Where is the "Jet" located that you "fabricated yourself". Is it on the "Straw" that goes into the bowl of the carb, on the side of it. You can unscrew it with a Flat Head driver. I didn't measure the one I have in there, but what size should it be for my elevation?
2. I Live in St. Pete Florida Elevation is 0
3. How much pressure should the Fuel pump create. No matter what I do, with the fuel pump rebuilds it seems the pump is barely moving any fuel. When cranking the engine, before it fires up, should the fuel pump move a lot of fuel? (If I remove the outlet from the carbs.. just to see if fuel is coming out) It just seems to dribble out.
Thanks for anyone who can help!
I have a few questions about the fuel pump rebuild that you did an
