I had asked a while back if it was possible to cut off the end of transduser wire, drill a hole in my PowerDrive shaft and put the wire inside the shaft. The wire comes out of the shaft where the shaft and motor screw together. I would then solder the wires back. I talked to Humminbird and they said no. I had done it before on an Eagle but that was may years ago.<br /><br />Well I did it and it worked. The biggest issue was to rewrap the wires the same way they came. I used aluminum foil to shield the wires from themselves and file the hole with silicone. I tested it this weekend and it worked just fine.
