Having a bad morning... Not only typed the wrong boat model (not that that matters) but forgot to put the outdrive's model number:
Boat is a DL-190 not a 120
Outdrive is a 1990 OMC Model # 986321
Also meant to mention - The shifting was a bit 'tight' feeling on this unit when I got it recently, doesn't hang up or anything but certainly not a 'shifts with a finger' deal either - But as mentioned, shifted fine, went to neutral fine, forward fine, reverse fine all day 1st time out in it until we came into dock, then stuck in reverse only no matter which direction you threw the shifter lever up front.
Once again, THANKS in advance for any useful hints or info!
Edit: For your protection
