folding tongue with hydraulic surge brakes?
oldsub86
Is there any reason why I cannot add a folding tongue kit to my trailer that has hydraulic surge brakes? I assume I could use a rubber flex hose to connect the lines on either side of the hinge and it should work fine.
Anyone out there done it? Or seen a factory setup?
Randy
deadstick
Re: folding tongue with hydraulic surge brakes?
my trailer has surge brakes and brake away tounge.it has a rubber hose coming from master cylinder and a quik disconect..
Silvertip
Yes you can add a swing tongue. You cannot, however, use regular hose for the joint. It must be flexible brake line hose just like those at each wheel on your car. Regular hose would burst at the first stop.
Splat
I would even consider springing for some steel braided brake line. A little extra protection, no to mention it won't buldge, although I don't think the pressure gets anywhere high enough for this to happen on a sirge system.
Bill
deadstick
Y Regular hose would burst at the first stop.
im sorry for not being clear in the first post.
the pic bellow shows a a quik disconnect. you will need one like this so your tongue will have the max travel.
click here for part # for this hose and coupler.
