Re: Fogging a fuel injected motor
Fogging any EFI does not cause problems with any sensors. However it can mess up the injectors in an MPI setup. With a TBI system, you can just fog like a carbed engine. With an MPI engine you don't want to squirt or spary fogging oil into the throttle plate. Merc and Volvo, you use a similar mixture of Gas, Fogging oil (or 2 stroke oil) mixed appropimatly 50-1 and fuel stabilizer (per lable).
Mix up a gallon or two in an outboard tank, hook it to your engine fuel filter and run the engine.
This won't smoke like a carbed engine, but it also doesn't plug or damage the fuel injectors. When you are done, dump the excess fogging mixture into the boats fuel tank, it won't cause any problems at all.
