Hi, I have been chasing a gear lube problem for a while and decided to ask someone who might know. I have a 94' Alpha One hooked to a 3.0L. I noticed the gear lube reservoir losing oil at an increasing rate and could not identify the source. No leaks in the garage, in the bottom of the boat or any sheen on the water. I thought maybe it was the brass fitting going through the transom and decided to check it and replace the bellows while there. Since then the gear lube level remains constant but it foams up while running. I haven't ran it for extended periods after noticing it. Lube in the drain plug is dark, no water down there. This past weekend changed the lower unit water pump looking for oil passage seals that may be bad, did not notice anything that could be leaking. I never noticed cloudy oil in the reservoir before. Any ideas?
Thanks,
Tbob in Louisiana
Thanks,
Tbob in Louisiana
