Put a new timer base on, starts at turn of a key
Pulled flywheel off to double check something, and because I like like to live life on the edge...
I noticed that the inner ring appears to be rubbing on the trigger. Should I scrape the epoxy off the timer base and try to adjust trigger? It's an expensive timer base so I don't want to risk burning it up...
Anxiously awaiting a reponse. I'm ready to take this project boat out today and see if it's worth the effort...
