jaredsandy
- Jul 21, 2001
- 3
I have a 60 HP Johnson (1992) whith electric start and theres a spot on the flywheel that has 5 missing teeth....it don't work well when it gets to that spot. But the teeth on the starter still look fine.<br />Is it easy to replace the flywheel?<br />It looks like you just remove the nut and use a puller to remove the flywheel. Is that correct and will this screw up the timing or anything?<br />Thanks
