flywheel removal
commissioner
I'm in the process of overhaulling my 1985 Johnson outboard<br />I'm having trouble removing the flywheel<br />I've got a hamonic puller on it and it won't break free<br />I've put heat to it , map gas, repeatedly<br />I've put a bar under the flywheel and rapped the top of the harmonic puller<br />I've soaked it in WD 40<br />Any Ideas?<br />11/25/03<br />I've tried the PB blaster oil and let it set over night,I tapped it with a 2pound hand sledge, I then used my 1/2" electric impact wrench,and then I put a pipe on a breaker bar and now my harmonic puller is just beinging to show stress cracks and still it isn't moving.
ezeke
Re: flywheel removal
When these fellows say tap, they mean hard. Give the balancer shaft a good solid hit and then tighten your harmonic balancer screws. Then repeat.
wayne h
Master Chief Petty Officer
wd 40 is not a penatrating oil. and be carful hitting the balancer to hard remember that every time you hit that you are shocking the bearings on the crank.heating with a torch is usless you will never get it hot enough with that kinda torch.i would leave pressure on the puller over night and get a good penatrating oil like PB BLASTER or somthing like that. remeber when you get it off to torque the nut and some anti-seize helps for removing it next time.
R.Johnson
If you have the proper puller, an air impact wrench will shock even the most stubborn ones loose. Be carefull with heat, or a hammer."Impropper puller, or puller hold down bolts" can lead to disaster.
