Re: Flywheel Puller
A harmonic balancer puller can be used. They are available at most autoparts stores for around $10. I have also seen a lot of posts stating that an air wrench is preferred, but since I don't have any, I can't say first hand, but it would make a lot of sense. As JB said, rapping on the shaft and prying on the flywheel is not recommended. Sometimes a rap on the end of the flywheel puller will be needed. Again, that is not recommended but sometimes there is no choice. Any rap on the end of the crank can hurt the bearings. We all know what you are going through. If you want the real tools, they usually are available at your local dealer, but they can be really expensive. Good luck.
