Before I removed my flywheel to service the ignition on a 3 horse rude, the flywheel had a bit of play in an up and down direction. This few thousands of an inch movement is considered normal and even necessary according to many authorities. After reinstalling the flywheel and torquing the nut to about 40 ft. pounds the wheel no longer has this play. Is the FW nut too tight? Should I reinstall and make sure I still have this play/movement? My torque wrench isn't graduated very finely so how critical is the movement? Thank you.
