Flywheel Magnets
SCzig
Does anyone know where to get some new magnets for a 1994 25hp Tohatsu?
pvanv
Re: Flywheel Magnets
You get a new flywheel. You will need the correct model/serial; year is unimportant.
Sea Rider
What happened to the original ones, popped off or a brilliant unskilled mech tried to remove flywheel by saving buying a flywheel extractor and hammering it sideways along breaking one or more magnets ?
Happy Boating
SCzig
nah, you could hear/feel some grinding when turning the flywheel by hand so pulled the flywheel (with a flywheel extractor) and noticed one of the mags was broken. all were loose I guess the epoxy had finally given away.
pvanv
Assuming you have an M25C2, which is quite obsolete. (Year of manufacture is unimportant for servicing a Tohatsu/Nissan: Model/Serial is everything)...
3A0060910M FLYWHEEL CUP FP5505-NO LONGER AVAILABLE
You are out of luck for a new part... Try the OB salvage shops.
Sea Rider
Have a Tohatsu 30 HP working with broken magnet epoxy re glued back, engine working fine, if broken magnet pieces are not missing, try re gluing back to same position or as Pvanv stated look for one at salvage yards.
Happy Boating
