Del R. Mabire
- Feb 10, 2007
- 9
I have replaced the flywheel magnets on my 175 Johnson o/b. The epoxy adhesive required mixing. I stirred the mixture as I spread it over the magnets and the flywheel. Nothing very vigrous but what seemed to be enough to mix paste with the hardner. After setting for 36 hrs the epoxy still has areas that are sticky.My question is : Is the epoxy like fiberglass which will eventually dry and cure when not properly mixed with its hardner?
