flywheel key 2
sambaylor
replace flywheel key with new key now flywheel rub the plate where the coils are mounted.didn't mess with that part.was i given the wrong woodruff key by my local dealer.any help need.thank you kihdly sambaylor
tashasdaddy
Re: flywheel key 2
key would have nothing to do with it. sounds like flywheel is cocked, not on straight. or torqued properly.
Joe Reeves
Re: flywheel key 2
Sam.... It would help if you listed what engine you're speaking of.
F_R
Re: flywheel key 2
It is possible that the wrong key is not allowing the flywheel to seat down on the taper properly. You can't expect it to work with the wrong parts. The key also has to be installed properly. Some follow the taper and some are installed vertical.
