86' johnson 90hp. I just bought it so I'm not positive when it was last ran. But when putting it on my boat, I noticed a power pack is bad (not getting spark in those plus) but primarily noticed, the flywheel would not spin a full rotation with the starter.
I figured it may be the starter. So took it off and it seemed fine. Pinion was able to fly up and down while off the boat.
Next, took the plus out and turned it over with the starter back on. That's when I noticed the flywheel was able to spin freely as it should! As I put one plug in at a time I could hear it "skipping" until I had all 4 back in and it was back to not making a full rotation. The more plugs i had in it, the longer the "skip" became. Too much compression is what dad called it. But he's not a boat guy.
Anyway, I did some research and tried spraying seafoam in the plug holes, it didn't change anything.
Can anyone tell me some ideas to try or what these symptoms are to look up for myself?
