Flywheel for Inboard vs I/O?
Speakrdude
Ensign
Is there a difference between a 14" flywheel for an inboard 350 with the aft mounted starter vs. a regular style 350 starter config? I cant get my starter to engage. Stater is about an inch to short in length to hit the teeth.
Bt Doctur
Re: Flywheel for Inboard vs I/O?
Not so much the flywheel but where the ring gear is located on it.I/B`s (Aft mounted)are different that I/O`s
Speakrdude
Ensign
Yeah, the ring gear on this flywheel is forward. I need the opposite.
Howard Sterndrive
on most, you can warm the ring gear evenly with a torch, and move it to the other side.
Speakrdude
Ensign
really? Never would have thought. What holds it in place with all the torque?
cr2k
rust expansion!
It's a shrink fit. Figure about 1/2 in wide and about 44 in. circ. that's around 22 square inches of contact.
Kinda like a big oil filter band wrench
Ayuh,... It's known as a Resistence Fit around here...
Knock it off the flywheel with a hammer,+ punch, no heat necessary...
Then heat the Ring Gear in the oven, set to HIGH, for 20 minutes...
Pull it out,+ drop it onto the flywheel,.... It'll literally fall into place on the flywheel...
Speakrdude
Ensign
Is there a "direction" of travel for the ring gear? What I mean by that is, if the gear was meant for a forward-mounted starter, when I press it off, does it need to be flipped over when I reinstall? It looks to be a straight tooth but not sure.
Thanks guys. You just saved me about $300.00.
Happy Thanksgiving!
Jim
Ayuh,... The Ring Gear is Bi-directional...
Matter of fact, I've flipped over questionable ring gears to get another lap outa 'em...
Speakrdude
Ensign
next issue. I removed the ring only to find that the flywheel is turned to a smaller diameter at that spot. Can this be installed backwards? I always thought that the damper had to be against the flat side of the flywheel. If I heat up the ring, will it expand enough to fit over the non-turned down part? Do I have the wrong flywheel?
Happy Thanksgiving all.
rodbolt
your flywheel isnt machined remount the ring gear. you will either need to have it machined or find the correct part.
Bt Doctur
Unless I`m wrong, that wheel is for a I/O not inboard.
rodbolt
not all inboards use a top mount rear entry starter, the really fun ones are on twins with bottom mounts :).
the flywheel in the pic looks to be for a bottom fwd mount starter and the aft edge was not machined to accept the aft mount starter ring gear.
Speakrdude
Ensign
So can I buy an automotive type at the local parts store and flip the ring gear? Or am I back to spending $250.00 for a used one?
f_inscreenname
You can try but I would take the gear with you when you go to pick it up. Not catching what motor it is for the best bet is to find the # of the flywheel you need and then do a Goggle search on - Inboard flywheel for a 350 and you will find it.
