Re: FlyBoyMark - Mercury 2 Strokes
Mercs site as of today:<br />Largest motor is 115 EFI<br /><br />Propshaft Horsepower: 115-hp (85.8 kW) <br />Max RPM (W.O.T.): 5000-6000 <br />Cylinders/Configuration: 4 (in-line) <br />Bore & Stroke: 3.11 in. x 3.495 in. (79mm x 88.8mm) <br />Fuel Induction System: 4 Valve Dual Overhead Cam - EFI <br />Displacement: 106.2 cu. in. (1741cc) <br />Exhaust System: Through Prop <br />Cooling System: Water cooled with thermostat <br />Ignition System: Capacitor Discharge <br />Starting System: Electric (Turnkey) <br />Alternator: 25 amp (315 watt) <br />Gear Ratio: 2.07:1 <br />Gear Shift: Remote (F-N-R) <br />Steering: Remote <br />Trim System: Power Trim <br />Shaft Length: 20 in. (508mm) <br />Weight-Dry: 386 lbs. (175 kg)
<br />Operator Warning Systems: Overheat, low oil pressure, overrev <br />Propeller Options: Black Max, Vengeance, QA3, QSS <br />Lubrication System: Wet sump with pressurized lube system
