Sea Rider
- Sep 20, 2008
- 12,345
My beloved 18 is undergoing a 600 hour full preventive maintenance, it's correctly flushed after each outing on muffs, for at least 10 minutes, while engine is on running at fast idle. Assume all Tohatsu owners flushes their OB's after use specially the ones used on salt waters. If so share your flushing experience. Do you flush your OB...
1-On muffs, with flushing attachment, barrel flushing.
2-For how long
3-While OB is on or off
4-If head gasket is removed after say 300 worked hours, do you expect to find all water passages clean, medium clean, salted, crusted, corroded ?
This will tell a lot about flushing method used, time spent while flushing and if flushed ON/Off...
Happy Boating
2-For how long
Happy Boating
