Hi all<br />I have a hydro electric 60 hp johnson changed out solenoid selector switch and got reverse and nuetral <br />back in it now but seems slow and slugish to go into neutral. when i try to start it on water it always seems like it is in foward gear and lurches me foward .I have read alot on forumes about flushing lower unit with atf fluid was going to try this weekend to see if that helps. how long running on muffs would you let atf stay in and do you shift gears to help it or just run in neutral?
