I posted a previous note regarding my 150 Ocean pro V6.....anyrate, I discovered a 3" long crack in the lower unit while on the water....still a mystery as I didn't run aground or note hitting any submerged objects...crack is located above the gear case, just below the cavitation plate on the port side of the "v", runs vertically..
so, outboard mechanic suggested I flush it w/ transmission fluid, take it to a welding shop and roll on, re-lube and roll on.... sounds good to me as I don't wanna B.O.A.T. yet...(break out another thousand)
so question is....does tranny fluid seem good, and will it harm the seals if I leave it in say overnight...don't see how it could be any worse than the previous lubrication of saltwater w/ a trace of oil...I just filled it w/ tranny fluid and have been turning it by hand....doesn't feel too rough or binding etc...so I'm ready to roll it to the welding man.....
yes I did limp it back at low low speed the short distance of 1/2 mile to the ramp after discovering the cracked gearcase.....
btw the gearcase is most likely from a 200HP as someone shortened the drivesahft splines and ground off the shaft below the splines...a mod suggested to me in another post to put on a V4 gearcase I have...
