I just purchased a 06 F90 Yamaha four stroke,and skeptical about flushing the motor after every use.The manual says to connect the water hose to the hose connecter on the motor and run the water for 15 min. without the engine running.I geuss this is the way the new motors are cause I seen a guy do it this way with a suzuki.The manual says its "the most thorough" way to wash the engine.Is this the best way to flush the motor or should I flush it the normal way by putting the flushing attachment on the leg and run the water and motor?<br /><br />P.S The manual also says not to run the motor while flushing with the hose connecter thats on the motor.It will damage the pump.<br /><br />Aloha, sym
