flush adapter FOR YAMAHA 650 WAVERUNNER
JSTSTRD
I am trying to install the fresh water adapter so I can run the engine on ground. I cant figure where i it goes. Can someone help? the repair manual shows a slot i dont have on my exhuast manifold.
Jeff Walkowiak
Re: flush adapter FOR YAMAHA 650 WAVERUNNER
there are 2 hoses one from the pump and one exiting the hull it goes in the exit hose, you need to crimp the exit hose behind the fitting when you flush it , that will work on most skies, be sure to follow the flushing instructions or damage will occur.
