Re: Fluid leaking behind prop (pic inside)
Don't want to start a new topic because of similar problem/question.
Just bought the boat and engine last week. We had to came back over a speed restricted canal (so low rpm) for 15 minutes. Drove back home with boat and engine on trailer for about 2 hours.
At home found some oil leaking at the prop (only there). Happily i found this thread and read also the info from JB. So most probably it will be unburned oil because of low RPM before shutting engine down. To me the oil seems quite dark in color.
If I leave my engine unused for let's say the next 4 weeks. Is it correct if i conclude that, when oil is still leaking after 4 weeks, the problem would be a sealing problem and if oil leak has stopped, it was most probably unburned oil? I am looking for an easier way then servicing the whole lower unit for (maybe) nothing. It's also my first engine, so i might be a bit overscared. I bought the OEM manual, so if needed replacement can be done.
The previous owner did change the lower unit oil last year and didn't found any evidence of water protrusion.
Engine is a 1998 Johnson 35HP 3 Cyl 2 Stroke with less then 100 hours.
Anybody that can see on the picture (oil color) which oil is leaking (lower or engine oil)?
