Re: Fluid for lower unit... What to use...
I suggest you purchase the proper gear lube sold by Mercury. Their "premium" gear lube is what you're looking for. I know folks use many different brands and types of gear lube, and some may be fine, however, the viscosity of marine gear lube is much thinner than automotive type. I also suggest you buy the hand pump (looks like a hand lotion dispenser with a hose attached) used to add the gear lube.<br /><br />G.I.Joes, my local sporting goods chain, sells Mercury oil & gear lube for less than the dealer. They also sell the pump... I'd suspect you too can get it from a sporting goods retailer.<br /><br />Walt
