Fisher King
- Jul 15, 2002
- 2
I have a 89' OMC(GM) 6 cyl 4.3 w/ cobra outdrive. At idle the oil pressure is low 5 - 15 but ocassionally jumps a little higher, during climb and at higher rpm the oil pressure picks up but occasionally drops also. Is there a good way to tell if the oil pump is going bad, do sending units tend to go bad, I assume this is the original sending unit and oil pump.
