Re: flounder lights
Commom enough over here to make or purchase your own. All you need is a 12v bulb, pole and wire with aligator clips.<br />Set up a 12v bulb inside some glass or clear plastic container that can be waterproofed, secure this to the end of a pole that you can easily carry around and attach the clips to a 12v battery. I use a 12v house alarm battery which is light to carry and easy to recharge.<br />Otherwise we also utilise "tilley" lamps (kerosene) which give out about 500 candle power and light up a huge area, but are a bit cumbersome to carry.<br />Mind you all our flounder are speared in less than 12" of water.<br />Ross
