Re: Floor Removal
Take a look at this Fishmaster and the rear wall, notice the jigged cuts into the sidewalls, and disregard the access doors for a moment.
I am considering a similar wall. On my 79, it has the boxed in floatation under the splashwell port and star. Star side center is my trim motor and taking up the remaining space is the perm fuel tank(flat model).
The wall will tie into the top cap and the floor and should tighten up the aft section of the cockpit. From there, I will build the aft deck. The overall opening is 22" high. Since I need access to the middle section for trim/tank, each side will get a folding seat which will use up 17" each side leaving around 28-29" for the width of the raised decking.
With only 22" of height, the wall will be solid across the top but cutaway on the bottom center 28". The aft deck will be a separate section built to "slide in" and fastened in such a way that it could be removed for maintenance and repair. This removable casting deck approximately 28" wide by 18" long by 15" deep will have a swiveleze pin base flanked by two storage hatches 11x15"
The house battery under the starboard seat and tools storage under the port side seat. The wall section above this deck will hold 6 rod holders/launchers and an LED light, one of many to be added. The top rail that exists will get some Bert Tracking for trolling.
VEADA has great seating at great prices. Not going with 2 more pedestal style because the hardware in very expensive. I pitched the entire bow seating and jump seat mess the boat came with. What it did have was 2 brand new captains chairs with all the base and pedestal hardware.
Trying to turn a 30 year old tinnie with wasted space in splashwell and transom design into a combination of a SFM and a FM is pretty crazy.
