Re: Floor Drain leaking water into boat? Is this right?
here's my assumption FWIW: I have a Key West that is pretty much a "bay boat" design--fairly flat bottom and low sides. It is not self bailing; the deck is at or below the waterline and therefore it does not have scuppers. There is a flat floor drain at the stern in front of the splashwell that drains the deck into the bilge, where the bilge pump evacuates the water. there is also a standard garboard drain plug. So if everything is working, water should never rise up through the floor drain, and any water that accumulates in the bilge is pumped out. I have seen water rise up through the floor: once when I forgot the plug, and once when the bilge pump failed and we had heavy rains fill the boat.
If I replaced the garboard plug with a ball-**** plug, and it malfunctioned, I'd have water coming in the boat when sitting still and going out when running--if the bilge pump also did not work. As OP described.
so Chris, you may be right, or he could have a boat like mine and I'm seeing the problem correctly, and differently from you. Only the OP can solve the mystery!
