Re: float spring....how to remove??
It should have a knurled end (kind of like the business end of a drive shaft, but smaller and the indents aren't as deep). Use some needle nose pliers and pull from the knurled end straight out. The pin should come out fairly easily. If you pull from the other end you could ruin the carb housing. Good luck...
