Float Lever Sticking 25hp 1991
Bob_VT
Re: Float Lever Sticking 25hp 1991
Properly rebuild the carb. They only stuck because something is gumming things up.
merc25rules
I did rebuild the carb and you are have convinced me my float is not sticking but i just cant figure out why then when i pump the primer bulb on tank that it wont stop and gas in coming out of the middle jet pin right at the center of the carb throat....any other suggestions...i rebuilt the whole carb and it starts and runs but it stalls after 60 seconds as it is not getting gas due to the bulb not getting full .....and comiong out of the aforementioned area
any help would be great.....thanks
