flat gap spark plugs
OMCFREAK
i was wondering if ther is any advantages on an old motor (67 fastwin 18)in using j4j quivelant in flat gap spark plugs or can flat gaps only be used on cd ignition
Paul Moir
Re: flat gap spark plugs
I doubt you'd get the magneto ignition system to jump the gap on a surface gap plug. Not under compression anyway.
WillyBWright
If it does fire, you'll burn the points rather quickly. Those are used on motors with electronic ignition. There are also no surface gap sparkplugs in the short "J" thread reach anyhow.
