Re: Fix it, bandaid it, or replace it?
Well, I could do the whole process on my own, however time is the big issue for me. I have my boat in Nashville & I'm finishing up school in Knoxville. Between 4th year mechanical engineering classes & work, about all of my time is taken up. I'm going to just need to pay to have something done. I could possibly do the plate on my own or rig a new boat up on my own, but the transom rebuild is just too labor/time consuming & I would have to pay to have it done.
Also, a little background on the boat: It is a 1992 model(rigged for an evinrude) that sat in my grandfather's backyard until 2005 with no engine ever being placed on it. It was a dealer leftover with no engine that my grandfather could not sell when he got out of the boat business. It was chained to a tree at one point by connecting the chain to the rear lifting eyes & the trailer was ripped out from underneath it at a substantial amount of speed(long story). I dont know if any internal damage occurred or not, but the transom eyes have been loose ever since that happened. I think the dealer that installed the yamaha just redrilled some holes without sealing the evinrude rigging holes up or sealing the holes they drilled. You can see water dripping through the transom on the lower mounting screw.
The git rot solution sounds interesting. I'm just not sure of the extent of my rot. The trim motor is able to lift the outer skin of the transom up when I put the transom saver on & the transom bows in where the engine weight is. How do I know if my boat is a good candidate for git rot?
If I do sell the boat outright, how much do you think I could get for it? A 19 year old boat with a bad transom, but it has a 2002 engine on it(mounted in 2005) with only 295 hours and a fairly new aluminum trailer.
The boat is in pretty nice shape other than the transom condition & maybe needing some new deck hatches. Its an old boat, but it hasn't truly been in use for very long. 6 years. I seem to think the rot is contained to the area around the splashwell & engine area. However, I don't know about the outer edges of the transom after being chained to that tree.
How would I test for stringer rot? The floor is solid everywhere. except for over the gas tank(needs new foam).
After all you guy's comments, I'm tempted to maybe dive into the transom repair. I'm just not sure whether to do seacast, wood, or git rot. My fear is the finishing fiberglass work. I think I could do the majority of the work, but making it look right in the end is what I'm worried about. I am good with tools, fixing cars, and do all my own maintenance on the boat, but my big saying is: "A man's gotta know his limitations." I don't know if I'm handy enough to dive into such a huge project.
Also the guy who wants to repair the transom, says he will essentially cut the whole back of the boat off & rebuild from there. That scares me a little bit.
I would be happy to have a new boat. I hate to see the old boat go because of a small problem & it has a little sentimental value, since my grandfather gave it to me. I like a cheap plate fix to get me a few years, but it ruins resale value & the constant worry of catastrophic failure.
Thanks guys!
