Fitting Size
FreeBeeTony
What thread size is the fitting onthe vent screw on an Alpha One? Dose that make sense?
Want to create a presure testing circuit........need to know the thread size on the outdrive.....I used the plastic fitting from the lube fill pump but its getting weak....threads are worn.
EddiePetty
Re: Fitting Size
:)...try your thread gauges!!! Usually 3/8-16.
Re: Fitting Size
Ayuh,... It's the standard Bolt size, not a fitting size... That's the Gotcha....
Ya need a Steel fitting off a bottlepump...
FreeBeeTony
Re: Fitting Size
So what exactly am I looking for???
And where do I look, in a plumbing store?
