Re: fitch help
is the engine having an issue? if so it may be your emm. make sure its not over heating from lack of water flow. also make sure the green wire in the forward wire terminal (terminal closest to flywheel) is good and secured . and the black tpc ground is two wires under the green ,make sure that also is secured. you may also try to reset the emm and see if codes go away,that is if you are seeing codes and engine is running fine. my engine a 1999 115 ficht had code 12 but engine was running fine.had the emm reset and code went away. good luck .
