Fishin for Bull Reds
LadyFish
Fun to catch, bull red.<br />
file.asp
<br /><br />How to rig for bull reds:<br /><br />Rig your surf rod with 20# Trilene XT, a redfish rig (available at any fishing store), a circle hook, and a spider weight.<br /><br />Bait; live mullet ( 7" range) or cut mullet.<br /><br />Wade out & cast between the 2nd & 3rd sand bar, bring back & put in PVC rod holder. Check cut bait every 30 min. & check live every 45 min.<br /><br />Note: Use a reel that will hold at least 200 yds. of 20# line.<br />
file.asp
<br /><br />For those that fish the along the Gulf Coast, much of the drill involves wade fishing. Wade fishing is probably the most most effective way to put a few fish on the stringer this time of year. If you are new to wade fishing there are a few things you need to know and have to be properly prepared.<br /><br />Here is a list of items that are basic needs of wade fishing. First will be a pair of chest waders. Rubber is fine, but neoprene is much more comfortable. Stocking foot waders with neoprene booties over them. They are really light. Next you need your rod and reel. A 7-7/12 ft. medium action casting rod and a good level wind reel will cover just about all applications for wading along the Gulf Coast. A quality wading belt is real handy. Use one that has a rod holder, needle nose pliers sheath and a quick release stringer holder. A life vest is also a real good idea, especially if you are unfamiliar with the area you are wading. A long (15-20 ft.) stringer with a float on the end or a donut with mesh net type stringer is necessary. Measuring fish while wading can be tricky, a good suggestion might be to put one of those 36 inch "rod rulers" on your rod. <br /><br />Now you are set to go wading, and if you gear up correctly, you'll look like a veteran and not a rookie. This is to say that if you can't catch fish, at least look like you can. Hook 'em! <br /> :cool:
D
DJ
Guest
Re: Fishin for Bull Reds
LadyFish,<br /><br />You may want to explain why you need a "quick release" stringer holder and why your bait should be on a line that can drift quite aways from you.<br /><br />Actually, there are two reasons.<br /><br />1. Sharks.<br /><br />2. Barracudas.<br /><br /> :eek: :eek:
snapperbait
Not to mention the possibility of accidently stepping on an un-suspecting stingray or other critter.. :eek:
Fly Rod
:) Nice fish!!! ;) That must go 30lbs or better!!<br /># 20lb test ?? You must like to play em for awhile!!!<br /><br />Do you fly fish for them??<br />If you do ,what type of fly do you use and color??? Sinking line etc:???
LadyFish
Actually these are local pictures and tips. Fly Rod I have fished for them from a boat and its great fun and quite a workout. I didn't use a fly we used med-light weight 7' rods and Shimano Curado reels baited with live shrimp or finger mullet.<br /><br />We always catch and release these big daddys, their not very good eating when they get this size. But give me a 28 incher and its time to get out the cast iron skillet and blackening seasoning.
dmurray
I love to fish for redfish in Panama City. I sure hope you did not keep that fish (although tempting). We found a nice spot the other day and wore our arms out, thanks for the tips.<br />Don
