I get an interference spike thru my VHF every time the Fishfinder transducer fires. It's a center console boat with Raytheon L470 fishfinder, Standard Horizon Intrepid VHF, and 3 ft base loaded Shakespear antenna on top of a 2 ft extension mounted to the highest point of the rail above the console (no t-top). Fishfinder is mounted on top of console, and is 3 ft from the base load of antenna. Space is limited, so the antenna wire is about 1 ft from the transducer cable at its closest point, but I've run them all over the place to keep them as far apart as possible everywhere else. Can't separate them any more than they are.<br /><br />Question: Is the interference coming in thru the antenna or thru the power wiring? If it's the power circuit, how do I isolate it?
