Fishfinder questions
retzman22
So my boat is 17ft deep v style side console. I currently have a cheap fishfinder at console with transom mount transducer. I want to rig the boat with bow and console fishfinders. I currently have a eagle 350 fishfinder/gps cheap combo on console. Was wondering which type of unit I should put on bow. I plan to eventually upgrade the eagle to something higher class. Do I want side and down imaging on bow or what is needed?
Thanks,
Ryan
Boatist
Re: Fishfinder questions
First welcome to the board.
I hope you get some answers from prople that have used the side imaging.
Only you can really answer your questions.
Side imaging alone add $600 to the Lowrance HDS units.
Many bass fishermen think it is worth it.
I went thru one of Lowrance's Classes at the boat show and can tell you it takes a while to get your brain to understand what you are seeing on the screen. I would also say the side imaging I think is only for shallow waters like for bass fishing down to 40 feet or so. It does allow you to see structure and shadows of structures.
It allows you to tell if some marks that look like fish on a normal fish finder really are. You know how an under water tree ot bush can look like fish. With the side scan you can pretty much tell it a tree or bush not fish.
Hummingbird also has units.
John_S
SS/SI and DS/DI require a constantly moving boat in a generally straight direction. If you are constantly turning your trolling motor, SS/SI screens become smeared and very difficult to read. DI/DS is more tolerable to the turning. These screens are more proportional than 2D and require more scruteny to read. The larger the screen the better. If you are a standing bass fisherman, you will want the largest screen possible, which are fairly expensive.
As just an obsessed fishermen, I run a HB SI/DI unit at the console, and an old 2D on the bow. I have convinced myself not to upgrade to SI on the bow, but I might go for a 2D/DI unit, though.
Given you are a happy Eagle/Lowrance owner, consider upgrading your console first, and moving your basic unit to the bow. You can get a HDS, and upgrade to SS latter. You can get to incrementally learn about the technology and have options down the road.
