phantomace08
- May 2, 2011
- 5
I have a Lowrance X47 that was working fine at the end of last year but will not turn on now. The power from the battery goes to the front of the boat to a "control panel" with a couple different switches. They all work fine (sometimes the lights will not work on a rocker switch or two without hitting it a bit) but I think there might be some corrosion in the cables. However, when I pulled the power input off the panel and tried to hook it up directly to the fish finder power cable, nothing happened. I don't get it!
Thanks!
Thanks!
