Fish finder shut down
damax
I just got a 20' Crestliner aluminum boat with a 200hp Honda and a hummingbird matrix fish finder. The hummingbird works just fine if I turn it on after the motor is running but, if I shut the motor down and re-start, the finder freezes up and will not turn off or anything until I pull it off the mount and then re-start it. Anyone know why or how to fix it? Thanks
GA_Boater
Running the FF of the starting battery, aren't you?
When the motor is starting, the voltage is dropping below the threshold for the FF.
How to fix - Cleaning all the electrical connections may fix it. The other thing is supply the juice to the FF from another battery. Do you have more than one battery?
