Re: First year of OMC 60 degree looper V4s??
60 degree V-4 loopers? To the best of my recollection, 1995. I had a '96 115. Great motor, but it had the infamous "bubble" under the rectifier/regulator problem, which they corrected on later models. To identify the newer powerhead, look for a 1/4" O.D. black rubber tube running from under the flywheel on the starboard side of the block, down to a fitting under the bottom cylinder (#3). This bleeds the air, which allowed the R/R to overheat and fail.
